1934 Philco 60B Alignment Problem
Check out Ron's write-up on the history and changes on the 60 here. You might find what you're looking for here, as far as the mystery part.
http://philcoradio.com/phorum/showthread.php?tid=15007
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
1934 Philco 60B Alignment Problem - by whirligig - 04-26-2018, 11:02 PM
RE: 1934 Philco 60B Alignment Problem - by PhilcoPhan1936 - 04-27-2018, 03:22 AM
RE: 1934 Philco 60B Alignment Problem - by morzh - 04-30-2018, 04:12 PM
RE: 1934 Philco 60B Alignment Problem - by morzh - 05-01-2018, 11:48 AM
RE: 1934 Philco 60B Alignment Problem - by Arran - 05-04-2018, 12:24 AM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 4864 online users. [Complete List]
» 1 Member(s) | 4863 Guest(s)
