1934 Philco 60B Alignment Problem
Thank you Jeff. That page breaks it all down. My guess is this is run #6 since it has no wave trap but I will confirm when I get to the shop Monday. You can imagine my frustration when the wiring don't match the schematic. Now I suspect the alignment instruction maybe different. This radio was previously recapped except for the micas. I may need to check those too if I can't improve the alignment.
1934 Philco 60B Alignment Problem - by whirligig - 04-26-2018, 11:02 PM
RE: 1934 Philco 60B Alignment Problem - by whirligig - 04-27-2018, 01:18 PM
RE: 1934 Philco 60B Alignment Problem - by morzh - 04-30-2018, 04:12 PM
RE: 1934 Philco 60B Alignment Problem - by morzh - 05-01-2018, 11:48 AM
RE: 1934 Philco 60B Alignment Problem - by Arran - 05-04-2018, 12:24 AM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 3046 online users. [Complete List]
» 2 Member(s) | 3044 Guest(s)
