Cheap xformer for tube output
I need to see if this will work on a Hallicrafters S-11. The original interstage transformer has a shorted winding. One side of the center tap is half the impedance of the other side causing one of the output tube to run scorching hot.
Cheap xformer for tube output - by OZ4 - 04-12-2018, 02:07 PM
RE: Cheap xformer for tube output - by whirligig - 04-27-2018, 01:27 PM
RE: Cheap xformer for tube output - by morzh - 04-27-2018, 07:22 PM
RE: Cheap xformer for tube output - by Arran - 04-28-2018, 03:48 AM
RE: Cheap xformer for tube output - by Phlogiston - 04-28-2018, 11:40 AM
RE: Cheap xformer for tube output - by codefox1 - 05-29-2018, 01:39 PM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 4988 online users. [Complete List]
» 3 Member(s) | 4985 Guest(s)
