new guy again,, 44 chassis
Threads: 271
City: Wilsonville
State, Province, Country: OR
You can leave the connection labeled "ground" unconnected to anything. Sometimes folks will connect it to a cold water pipe if you still have copper pipe, or to an earth ground rod, or to the ground in their electrical system. This ensures the chassis is at ground potential and can sometimes help reduce unwanted electrical noise.
The connection labeled "antenna" is where you connect that 20 foot wire. You do not connect the antenna and ground together.
RE: new guy again,, 44 chassis - by klondike98 - 04-27-2018, 05:32 PM
91H Code 126 Restore
When it comes to the cloth covered power cords, if they are not frayed, and are flexible, and if I can bend one without ...Arran — 06:21 PM |
Could be. The central cylinder is OK, but the sides are...well. What's done is done.
I wonder if some standard bobbine w...morzh — 06:02 PM |
Mike;
As I was saying it doesn't look like they used much of a bobbin for the field coil, not like a Magnavox one wou...Arran — 05:49 PM |
This AK84 was bought, I think, last fall.
For a whopping $100.
It has been, according to the seller, restored.
As I go ...morzh — 05:48 PM |
Plus I forgot that I have a spare complete Philco FC speaker, that would work perfectly, now that I don’t need it. Got i...Radios1340 — 05:36 PM |
Duh! I guess I can’t read an ohm meter today. I took the oscillator coil out and will take some readings tomorrow.Radios1340 — 05:30 PM |
Well, I killed the coil.
Tried to get to the end of that oxidated spot, but while holding the coil in hand, i let it sl...morzh — 05:27 PM |
It does not require taking apart.
Find an opening, any gap that would lead inside, where the resistive element and the ...morzh — 04:59 PM |
Philco 70 antenna lead
I agree. From the ones I've worked on its always been that green corrosion that causes the coils to open.Jim Dutridge — 04:34 PM |
Well I'm making good progress.
All the bakelite blocks have been recapped. I found that using a heat gun and skinny ...RealRider — 02:35 PM |
There are currently 4986 online users. [Complete List] » 3 Member(s) | 4983 Guest(s)
