bakelight block potting compound?????
Second ditto.
Potting is a waste. It was necessary as they used shell-less capacitors that needed some sort of insulation from the environment. You are putting new caps in it that are already self-sufficient. No potting required.
RE: bakelight block potting compound????? - by morzh - 04-29-2018, 01:11 PM
91H Code 126 Restore
There are currently 2228 online users. [Complete List]
» 2 Member(s) | 2226 Guest(s)
