Model 60 Wiring diagram
There were several changes made during production. You want to make sure you use the proper one to restore yours. Ron documented it here:
http://philcoradio.com/phorum/showthread.php?tid=15007
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
Model 60 Wiring diagram - by emcjim - 04-29-2018, 12:05 PM
RE: Model 60 Wiring diagram - by PhilcoPhan1936 - 04-29-2018, 04:21 PM
RE: Model 60 Wiring diagram - by morzh - 04-29-2018, 05:20 PM
RE: Model 60 Wiring diagram - by Kestas - 04-30-2018, 12:53 PM
RE: Model 60 Wiring diagram - by emcjim - 05-01-2018, 01:21 PM
91H Code 126 Restore
There are currently 4527 online users. [Complete List]
» 1 Member(s) | 4526 Guest(s)
