bakelight block potting compound?????
i was leaning that way anyway and thanks, empty they shall stay. by the way though 3140 is an electronic grade silicone that DOES NOT contain acetic acid. its runny and can be painted with an acid brush and as i recall was the ONLY rtv cited in the old navy aircraft wiring manual. i know very well what all the other stuff does! you should see what it does to canon plugs when used in lieu of a packing grommet!
RE: bakelight block potting compound????? - by falcon123 - 04-30-2018, 12:49 AM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 4955 online users. [Complete List]
» 2 Member(s) | 4953 Guest(s)
