1934 Philco 60B Alignment Problem
I have a question, on the dial it has the calibration of both the bc band and the sw band. What frequencies does the sw band cover?
1934 Philco 60B Alignment Problem - by whirligig - 04-26-2018, 11:02 PM
RE: 1934 Philco 60B Alignment Problem - by morzh - 04-30-2018, 04:12 PM
RE: 1934 Philco 60B Alignment Problem - by morzh - 05-01-2018, 11:48 AM
RE: 1934 Philco 60B Alignment Problem - by Radioroslyn - 05-01-2018, 04:23 PM
RE: 1934 Philco 60B Alignment Problem - by Arran - 05-04-2018, 12:24 AM
91H Code 126 Restore
There are currently 4920 online users. [Complete List]
» 1 Member(s) | 4919 Guest(s)
