1934 Philco 60B Alignment Problem
Just reviewed the Philco 66 schematic from Nostalgia Air and the layout looks just like the radio I've been aligning. I need to get to the bottom of this when I get to the shop in the morning.
1934 Philco 60B Alignment Problem - by whirligig - 04-26-2018, 11:02 PM
RE: 1934 Philco 60B Alignment Problem - by morzh - 04-30-2018, 04:12 PM
RE: 1934 Philco 60B Alignment Problem - by morzh - 05-01-2018, 11:48 AM
RE: 1934 Philco 60B Alignment Problem - by whirligig - 05-02-2018, 01:39 AM
RE: 1934 Philco 60B Alignment Problem - by Arran - 05-04-2018, 12:24 AM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 4954 online users. [Complete List]
» 1 Member(s) | 4953 Guest(s)
