Sansei Polaris
No printed circuit board, nothing but ceramic disk capacitors (other that the electrolytics) and tube sockets have been cleaned. The resistor that I replaced is now discolored from heat, so I'm pretty sure that it's the wrong value. Looks like as good of a place to start as any.
Dave
Sansei Polaris - by Dave - 06-12-2010, 07:26 PM
Re: Sansei Polaris - by codefox1 - 06-13-2010, 11:05 AM
Re: Sansei Polaris - by Dave - 06-13-2010, 12:45 PM
Re: Sansei Polaris - by denver - 06-13-2010, 05:26 PM
Re: Sansei Polaris - by denver - 06-14-2010, 02:36 PM
Eico 232 VTVM Schematic
There are currently 8875 online users. [Complete List]
» 1 Member(s) | 8874 Guest(s)
