Philco 40-150 Electrolytic can replacement
I did not see anything on EBAY but you are correct the prices can be out there!   Love to hit Kutztown but we always seem to have something else going on.  I can try posing on the Antique Radio Forum as well,  we have some local guys that might have what I need.
73's  Bob
RE: Philco 40-150 Electrolytic can replacement - by bikenepa - 05-03-2018, 08:09 AM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 2271 online users. [Complete List]
» 1 Member(s) | 2270 Guest(s)
