Stewart Warner R-137-A
Good idea,s guy's.
Will check the cadohm resistor as well as the grid caps and let you know what I find.
murf
Stewart Warner R-137-A - by murf - 05-01-2018, 06:21 PM
RE: Stewart Warner R-137-A - by David - 05-01-2018, 07:30 PM
RE: Stewart Warner R-137-A - by murf - 05-01-2018, 09:58 PM
RE: Stewart Warner R-137-A - by Eliot Ness - 05-02-2018, 07:22 AM
RE: Stewart Warner R-137-A - by murf - 05-02-2018, 10:19 PM
RE: Stewart Warner R-137-A - by gregb - 05-02-2018, 10:46 PM
RE: Stewart Warner R-137-A - by Arran - 05-03-2018, 12:21 AM
RE: Stewart Warner R-137-A - by murf - 05-03-2018, 03:16 PM
RE: Stewart Warner R-137-A - by murf - 05-03-2018, 09:15 PM
RE: Stewart Warner R-137-A - by gregb - 05-03-2018, 09:41 PM
RE: Stewart Warner R-137-A - by murf - 05-04-2018, 06:40 PM
RE: Stewart Warner R-137-A - by gregb - 05-04-2018, 07:17 PM
RE: Stewart Warner R-137-A - by murf - 05-11-2018, 09:55 PM
RE: Stewart Warner R-137-A - by murf - 05-29-2018, 09:27 PM
RE: Stewart Warner R-137-A - by Radioroslyn - 05-29-2018, 10:16 PM
RE: Stewart Warner R-137-A - by murf - 05-30-2018, 04:46 PM
RE: Stewart Warner R-137-A - by Radioroslyn - 05-30-2018, 04:54 PM
RE: Stewart Warner R-137-A - by murf - 05-31-2018, 09:27 PM
There are currently 9973 online users. [Complete List]
» 3 Member(s) | 9970 Guest(s)
