Buzz or hum on station only
If your power supply is of the switching type, it can, even if producing clean voltages, radiate EMI. When you made it, have you followed standard anti-EMI practices? One way of remedying this would be putting the power supply in a metal grounded box (grounded from outlet PE), and put a ferrite bead (make several turns) around the cable, as close as possible to the box.
This is, of course, if your voltages out of the power supply are clean.
Buzz or hum on station only - by epdowd - 05-03-2018, 11:56 PM
RE: Buzz or hum on station only - by Arran - 05-04-2018, 02:22 AM
RE: Buzz or hum on station only - by morzh - 05-04-2018, 08:05 AM
RE: Buzz or hum on station only - by epdowd - 05-09-2018, 11:56 PM
RE: Buzz or hum on station only - by epdowd - 05-13-2018, 02:57 PM
RE: Buzz or hum on station only - by morzh - 05-13-2018, 03:45 PM
RE: Buzz or hum on station only - by gregb - 05-13-2018, 06:05 PM
RE: Buzz or hum on station only - by epdowd - 06-02-2018, 10:00 AM
91H Code 126 Restore
