new guy again,, 44 chassis
Thought id start a new thresd [the new thread was merged with the original thread to keep the discussion together..Moderator]
question I have is Does anyone know or can explain the 3 Adjustments on the back?
3 adjustments on the back (wave trap and 2 compensating condensers)
I would think they would be for the end user to adjust(do to there location)
new guy again,, 44 chassis - by safeshow - 04-27-2018, 11:41 AM
RE: new guy again,, 44 chassis - by safeshow - 04-27-2018, 12:34 PM
RE: new guy again,, 44 chassis - by morzh - 04-27-2018, 01:23 PM
RE: new guy again,, 44 chassis - by klondike98 - 04-27-2018, 02:16 PM
RE: new guy again,, 44 chassis - by safeshow - 04-27-2018, 03:19 PM
RE: new guy again,, 44 chassis - by safeshow - 04-27-2018, 03:51 PM
RE: new guy again,, 44 chassis - by klondike98 - 04-27-2018, 05:32 PM
RE: new guy again,, 44 chassis - by safeshow - 04-27-2018, 06:44 PM
RE: new guy again,, 44 chassis - by safeshow - 04-27-2018, 07:00 PM
RE: new guy again,, 44 chassis - by klondike98 - 04-27-2018, 07:04 PM
RE: new guy again,, 44 chassis - by klondike98 - 04-28-2018, 09:08 AM
RE: new guy again,, 44 chassis - by safeshow - 05-02-2018, 10:05 PM
RE: new guy again,, 44 chassis - by klondike98 - 05-02-2018, 10:53 PM
RE: new guy again,, 44 chassis - by safeshow - 05-03-2018, 08:32 AM
RE: new guy again,, 44 chassis - by safeshow - 05-04-2018, 11:29 AM
RE: new guy again,, 44 chassis - by klondike98 - 05-04-2018, 12:53 PM
RE: new guy again,, 44 chassis - by morzh - 05-04-2018, 03:20 PM
RE: new guy again,, 44 chassis - by klondike98 - 05-05-2018, 05:54 PM
New guy chassis 44 - by safeshow - 05-05-2018, 05:30 PM
RE: New guy chassis 44 - by morzh - 05-05-2018, 05:33 PM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 4253 online users. [Complete List]
» 2 Member(s) | 4251 Guest(s)
