philco 16B
I have done a couple of 16s. I used O-rings from Lowe's. I don't remember the number for the larger one, seems like no. 17 or something. The smaller one was harder to find, but I found it at Lowe's also. Look where the copper fittings are. They have the tees that do not require solder, the tubing just pushes in and locks. They have a replacement O-ring for them. The brand is Grip N Go, you need the 1/2" size. The part no is 519-12. For the very large rubber on the drum, I used an oil filter gasket.
M R Radios   C M Tubes
philco 16B - by theboyzz - 06-15-2010, 08:57 PM
RE: philco 16B - by Steve Davis - 04-08-2015, 10:59 PM
RE: philco 16B - by Stall-U-Rated - 02-02-2019, 06:53 PM
RE: philco 16B - by morzh - 02-02-2019, 07:56 PM
RE: philco 16B - by Ron Ramirez - 02-02-2019, 08:27 PM
RE: philco 16B - by morzh - 02-02-2019, 08:51 PM
RE: philco 16B - by Ron Ramirez - 02-03-2019, 09:07 AM
RE: philco 16B - by Kenneth F. Besso Jr. - 02-03-2019, 07:07 PM
RE: philco 16B - by radiohenry - 02-04-2019, 06:46 PM
Re: philco 16B - by Ron Ramirez - 06-15-2010, 09:58 PM
Re: philco 16B - by Ron Ramirez - 06-15-2010, 10:01 PM
Re: philco 16B - by Steve Davis - 06-15-2010, 10:04 PM
Re: philco 16B - by Steve Davis - 06-15-2010, 10:06 PM
Re: philco 16B - by theboyzz - 06-15-2010, 10:09 PM
Re: philco 16B - by Ron Ramirez - 06-15-2010, 10:48 PM
Re: philco 16B - by Steve Davis - 06-15-2010, 11:17 PM
Re: philco 16B - by Ron Ramirez - 06-17-2010, 07:39 AM
Re: philco 16B - by Steve Davis - 06-17-2010, 07:05 PM
Re: philco 16B - by Ron Ramirez - 06-17-2010, 07:13 PM
Re: philco 16B - by Steve Davis - 06-17-2010, 07:20 PM
There are currently 10532 online users. [Complete List]
» 3 Member(s) | 10529 Guest(s)
