noise on radio during the day **SOLVED**
Threads: 4
City: Monteith, Ontario CA
(05-06-2018, 11:47 PM)Radioroslyn Wrote: Yous guys need to start collecting more farm sets!!!!!!!
Yes, farm sets are great at getting rid of mains noise, and when the power is off over a wide area they perform well, at least the couple that I have used do. I have a nice Viking (Phonola) A+B set here that is a fabulous receiver, but ..... being a battery set doesn't help under normal circumstances during the day, when the RF noise is so loud.
We have no AM stations around here....none. During the day on AM all I get is noise, but as the sun approaches the horizon at dusk, the noise diminishes and the bands come alive with all manner of AM stations, from LF beacons to the pulpit pounders on SW.
RE: noise on radio during the day - by John Bartley - 05-07-2018, 07:47 AM
91H Code 126 Restore
When it comes to the cloth covered power cords, if they are not frayed, and are flexible, and if I can bend one without ...Arran — 06:21 PM |
Could be. The central cylinder is OK, but the sides are...well. What's done is done.
I wonder if some standard bobbine w...morzh — 06:02 PM |
Mike;
As I was saying it doesn't look like they used much of a bobbin for the field coil, not like a Magnavox one wou...Arran — 05:49 PM |
This AK84 was bought, I think, last fall.
For a whopping $100.
It has been, according to the seller, restored.
As I go ...morzh — 05:48 PM |
Plus I forgot that I have a spare complete Philco FC speaker, that would work perfectly, now that I don’t need it. Got i...Radios1340 — 05:36 PM |
Duh! I guess I can’t read an ohm meter today. I took the oscillator coil out and will take some readings tomorrow.Radios1340 — 05:30 PM |
Well, I killed the coil.
Tried to get to the end of that oxidated spot, but while holding the coil in hand, i let it sl...morzh — 05:27 PM |
It does not require taking apart.
Find an opening, any gap that would lead inside, where the resistive element and the ...morzh — 04:59 PM |
Philco 70 antenna lead
I agree. From the ones I've worked on its always been that green corrosion that causes the coils to open.Jim Dutridge — 04:34 PM |
Well I'm making good progress.
All the bakelite blocks have been recapped. I found that using a heat gun and skinny ...RealRider — 02:35 PM |
There are currently 2676 online users. [Complete List] » 2 Member(s) | 2674 Guest(s)
