Kirk's 37-610
Jeepeto
Thanks. My goal in this particular case was to give the radio a temporary speaker, considering Kirk did not provide one - only the chassis Icon_smile , to test the radio and to align it.
Which makes it not super-important as the original speaker eventually will be connected (Kirk claims he found it). Even though the impedance is several times that of what it should be, it still works just fine.
Mike.
Kirk's 37-610 - by morzh - 03-31-2018, 10:43 PM
RE: Kirk's 37-610 - by morzh - 04-01-2018, 01:24 PM
RE: Kirk's 37-610 - by morzh - 04-16-2018, 11:15 AM
RE: Kirk's 37-610 - by WyTex - 04-16-2018, 11:55 AM
RE: Kirk's 37-610 - by morzh - 04-16-2018, 12:13 PM
RE: Kirk's 37-610 - by WyTex - 04-16-2018, 01:28 PM
RE: Kirk's 37-610 - by morzh - 05-04-2018, 08:36 PM
RE: Kirk's 37-610 - by morzh - 05-05-2018, 07:34 PM
RE: Kirk's 37-610 - by Jeepeto - 05-07-2018, 05:26 PM
RE: Kirk's 37-610 - by morzh - 05-07-2018, 06:10 PM
The speaker table error?
Philco 70 antenna lead
