Scott 16A
I am pretty sure you don't have to change anything if using any glass 6L6 tube.
Scott 16A - by rfeenstra - 01-28-2018, 03:03 PM
RE: Scott 16A - by Brad Winder - 01-29-2018, 10:46 PM
RE: Scott 16A - by morzh - 01-30-2018, 10:20 AM
RE: Scott 16A - by rfeenstra - 01-30-2018, 06:39 PM
RE: Scott 16A - by Electrothaumaturgist - 01-30-2018, 07:37 PM
RE: Scott 16A - by rfeenstra - 01-30-2018, 08:31 PM
RE: Scott 16A - by rfeenstra - 03-03-2018, 03:43 PM
RE: Scott 16A - by Phlogiston - 03-03-2018, 05:16 PM
RE: Scott 16A - by rfeenstra - 03-03-2018, 08:51 PM
RE: Scott 16A - by Phlogiston - 03-03-2018, 09:02 PM
RE: Scott 16A - by rfeenstra - 03-03-2018, 09:21 PM
RE: Scott 16A - by rfeenstra - 03-03-2018, 11:52 PM
RE: Scott 16A - by Phlogiston - 03-04-2018, 10:41 AM
RE: Scott 16A - by rfeenstra - 05-08-2018, 12:21 AM
RE: Scott 16A - by morzh - 05-08-2018, 08:58 AM
RE: Scott 16A - by Arran - 05-09-2018, 05:05 AM
RE: Scott 16A - by rfeenstra - 05-09-2018, 08:48 AM
RE: Scott 16A - by morzh - 05-09-2018, 09:49 AM
RE: Scott 16A - by Phlogiston - 05-09-2018, 10:02 AM
Philco 630csx power cord
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
I posted this on FB but knowing that not all of us use social media, it seemed sensible to ask my question here.  I r...Tynwald — 08:07 PM
Philco 40-155
At last, got this working well. Impressed has really nice reception and tone. Had a bad connection on one of the capaci...rogerh — 07:44 PM
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
There are currently 2582 online users. [Complete List]
» 2 Member(s) | 2580 Guest(s)
