Philco Hippo 46-620 Code 128
Reminds me of an old radio show called "Let Pretend"
Figure out which tube (s) it uses as Tom mentions and renumber the diagram to match.
From what I remember the big difference between the runs is the spkr
some used pm vs electrodynamic. Not a big deal.
Philco Hippo 46-620 Code 128 - by jamr005 - 05-08-2018, 07:54 PM
RE: Philco Hippo 46-620 Code 128 - by Patrick - 05-08-2018, 09:11 PM
RE: Philco Hippo 46-620 Code 128 - by Ron Ramirez - 05-09-2018, 06:27 AM
RE: Philco Hippo 46-620 Code 128 - by Kestas - 05-09-2018, 01:48 PM
RE: Philco Hippo 46-620 Code 128 - by 35Z5 - 05-09-2018, 03:14 PM
RE: Philco Hippo 46-620 Code 128 - by morzh - 05-09-2018, 03:30 PM
RE: Philco Hippo 46-620 Code 128 - by 35Z5 - 05-09-2018, 06:01 PM
RE: Philco Hippo 46-620 Code 128 - by Radioroslyn - 05-09-2018, 06:25 PM
RE: Philco Hippo 46-620 Code 128 - by David - 05-09-2018, 09:40 PM
RE: Philco Hippo 46-620 Code 128 - by Radioroslyn - 05-09-2018, 10:26 PM
RE: Philco Hippo 46-620 Code 128 - by Arran - 05-10-2018, 12:15 AM
RE: Philco Hippo 46-620 Code 128 - by 35Z5 - 05-10-2018, 10:02 AM
RE: Philco Hippo 46-620 Code 128 - by klondike98 - 05-10-2018, 01:10 PM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 3651 online users. [Complete List]
» 2 Member(s) | 3649 Guest(s)
