Philco Hippo 46-620 Code 128
Looking at the bottom of the audio output tube socket and determine which pin goes to the output transformer. If its is pin2 tube should be 50A5 if pin3 tube should be 50L6. David
Philco Hippo 46-620 Code 128 - by jamr005 - 05-08-2018, 07:54 PM
RE: Philco Hippo 46-620 Code 128 - by Patrick - 05-08-2018, 09:11 PM
RE: Philco Hippo 46-620 Code 128 - by Ron Ramirez - 05-09-2018, 06:27 AM
RE: Philco Hippo 46-620 Code 128 - by Kestas - 05-09-2018, 01:48 PM
RE: Philco Hippo 46-620 Code 128 - by 35Z5 - 05-09-2018, 03:14 PM
RE: Philco Hippo 46-620 Code 128 - by morzh - 05-09-2018, 03:30 PM
RE: Philco Hippo 46-620 Code 128 - by 35Z5 - 05-09-2018, 06:01 PM
RE: Philco Hippo 46-620 Code 128 - by Radioroslyn - 05-09-2018, 06:25 PM
RE: Philco Hippo 46-620 Code 128 - by David - 05-09-2018, 09:40 PM
RE: Philco Hippo 46-620 Code 128 - by Radioroslyn - 05-09-2018, 10:26 PM
RE: Philco Hippo 46-620 Code 128 - by Arran - 05-10-2018, 12:15 AM
RE: Philco Hippo 46-620 Code 128 - by 35Z5 - 05-10-2018, 10:02 AM
RE: Philco Hippo 46-620 Code 128 - by klondike98 - 05-10-2018, 01:10 PM
91H Code 126 Restore
There are currently 4969 online users. [Complete List]
» 1 Member(s) | 4968 Guest(s)
