Philco Hippo 46-620 Code 128
There's a major differences between the 50A5 and the 50L6, 50A5 is a loktal base tube the 50L6 is an octal. They use two different sockets.
Philco Hippo 46-620 Code 128 - by jamr005 - 05-08-2018, 07:54 PM
RE: Philco Hippo 46-620 Code 128 - by Patrick - 05-08-2018, 09:11 PM
RE: Philco Hippo 46-620 Code 128 - by Ron Ramirez - 05-09-2018, 06:27 AM
RE: Philco Hippo 46-620 Code 128 - by Kestas - 05-09-2018, 01:48 PM
RE: Philco Hippo 46-620 Code 128 - by 35Z5 - 05-09-2018, 03:14 PM
RE: Philco Hippo 46-620 Code 128 - by morzh - 05-09-2018, 03:30 PM
RE: Philco Hippo 46-620 Code 128 - by 35Z5 - 05-09-2018, 06:01 PM
RE: Philco Hippo 46-620 Code 128 - by Radioroslyn - 05-09-2018, 06:25 PM
RE: Philco Hippo 46-620 Code 128 - by David - 05-09-2018, 09:40 PM
RE: Philco Hippo 46-620 Code 128 - by Radioroslyn - 05-09-2018, 10:26 PM
RE: Philco Hippo 46-620 Code 128 - by Arran - 05-10-2018, 12:15 AM
RE: Philco Hippo 46-620 Code 128 - by 35Z5 - 05-10-2018, 10:02 AM
RE: Philco Hippo 46-620 Code 128 - by klondike98 - 05-10-2018, 01:10 PM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 4920 online users. [Complete List]
» 2 Member(s) | 4918 Guest(s)
