Philco Stereophonic Hi Fi Radio M-1001-124
Methinks it is. Your is a 475@175v-20-20mfd@ 150v. The diagram I found varies a little but what a few mfd's among friends. First set I've seen w/a tube mux circuit.
RE: Philco Stereophonic Hi Fi Radio M-1001-124 - by Radioroslyn - 05-10-2018, 09:05 AM
91H Code 126 Restore
There are currently 4902 online users. [Complete List]
» 1 Member(s) | 4901 Guest(s)
