Philco Stereophonic Hi Fi Radio M-1001-124
35Z5, is that an RCA 4RC96 by chance that has the PP 6BQ5 op tubes? I have one of those (minus the extra speaker) - one of my favorite radios. What is the Silvertone model?
RE: Philco Stereophonic Hi Fi Radio M-1001-124 - by gcerio - 05-13-2018, 02:44 PM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 3790 online users. [Complete List]
» 1 Member(s) | 3789 Guest(s)
