Buzz or hum on station only
It is had to understand and help without schematic or seeing what it is. If you could scan the sch and provide the photo of what you've done we could try to at least attempt something, else it's just guessing.
It is not a type of board, I could guarantee you.
Without understanding the possible reason you are destined to keep struggling.
Buzz or hum on station only - by epdowd - 05-03-2018, 11:56 PM
RE: Buzz or hum on station only - by Arran - 05-04-2018, 02:22 AM
RE: Buzz or hum on station only - by morzh - 05-04-2018, 08:05 AM
RE: Buzz or hum on station only - by epdowd - 05-09-2018, 11:56 PM
RE: Buzz or hum on station only - by epdowd - 05-13-2018, 02:57 PM
RE: Buzz or hum on station only - by morzh - 05-13-2018, 03:45 PM
RE: Buzz or hum on station only - by gregb - 05-13-2018, 06:05 PM
RE: Buzz or hum on station only - by epdowd - 06-02-2018, 10:00 AM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 4731 online users. [Complete List]
» 2 Member(s) | 4729 Guest(s)
