Question on my Philco 41-295 lamp
Felt is too thick for the metal dial plate. The dial pointer won't move. It needs to be re-flocked. You can find brown flocking material (almost like a brown dust in texture) online. Just use spray adhesive and sprinkle some on.
Question on my Philco 41-295 lamp - by nortonz - 05-15-2018, 03:32 PM
RE: Question on my Philco 41-295 lamp - by NostalgiaRadioTime - 05-15-2018, 11:36 PM
RE: Question on my Philco 41-295 lamp - by Arran - 06-12-2018, 02:45 AM
RE: Question on my Philco 41-295 lamp - by Arran - 06-13-2018, 12:31 AM
RE: Question on my Philco 41-295 lamp - by Arran - 06-14-2018, 03:15 AM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 4901 online users. [Complete List]
» 2 Member(s) | 4899 Guest(s)
