Question on my Philco 41-295 lamp
I scraped the old flock off, and I ordered some flock, but looks like it's coming from China. I my just try the felt, I already have some, besides haven't been able to find needle for it, but I found a second hand for a old clock, that's the same size. So I have to modify it anyway. It should work. I have the glass on order, not sure when it will show up.
   Had to restore the face plate, the letters were all worn off. Put new letters on, and repainted the gold trim. Turned out pretty good if I do say. Here's a picture.
[attachment=16411]
I know some of the letters aren't strate, but it was the best I could do. Ended up distroying the word Loud, so had to replace it one letter at a time, that was fun. It looks much better than it did. This was my first time replaces the letters.
Michael
Philco 41-295X 4 band radio.
I'm 67 years old, in north Idaho.
Question on my Philco 41-295 lamp - by nortonz - 05-15-2018, 03:32 PM
RE: Question on my Philco 41-295 lamp - by nortonz - 05-18-2018, 01:31 AM
RE: Question on my Philco 41-295 lamp - by Arran - 06-12-2018, 02:45 AM
RE: Question on my Philco 41-295 lamp - by Arran - 06-13-2018, 12:31 AM
RE: Question on my Philco 41-295 lamp - by Arran - 06-14-2018, 03:15 AM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 2910 online users. [Complete List]
» 2 Member(s) | 2908 Guest(s)
