Question on my Philco 41-295 lamp
Thanks for the input, but the base for the pointer in still there, just the needle was broken off. I bought a set of hands for a old clock a few years ago, that I never used. The second hand is the perfect size for the pointer, just have to paint it white. Will bend the top to fit, and a little gorilla glue to hold it in place.
This is the first time using water slide graphics, it was interesting. Took a few try's to get it on. The volume got messed up the first try, luckily there were 2 for each one. The second Volume I got on,  but then I couldn't get it to move in to place. So I left it there. It's not centered, and too close to the edge. Unfortunately the l
loud graphic got ruined, both of them. Had to take letters from the other left over words to make it, so one letter at a time. Just couldn't get it straight. At least it looks like I just put it on a slant.
Michael
Philco 41-295X 4 band radio.
I'm 67 years old, in north Idaho.
Question on my Philco 41-295 lamp - by nortonz - 05-15-2018, 03:32 PM
RE: Question on my Philco 41-295 lamp - by nortonz - 05-18-2018, 12:01 PM
RE: Question on my Philco 41-295 lamp - by Arran - 06-12-2018, 02:45 AM
RE: Question on my Philco 41-295 lamp - by Arran - 06-13-2018, 12:31 AM
RE: Question on my Philco 41-295 lamp - by Arran - 06-14-2018, 03:15 AM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 2304 online users. [Complete List]
» 1 Member(s) | 2303 Guest(s)
