Sears Model 3351 132.802
[attachment=16424][attachment=16424]
Found this at the local flea market yesterday and the price was right. Nice little 5 tube AC/DC set with 4 push buttons. The push buttons move the main tuner and are adjusted by turning a screw that adjust the movement of C1 and C2.    http://www.nostalgiaair.org/pagesbymodel...016962.pdf  Beitman is a little easier to read.
Sears Model 3351 132.802 - by David - 05-20-2018, 06:05 PM
RE: Sears Model 3351 132.802 - by David - 05-20-2018, 06:07 PM
RE: Sears Model 3351 132.802 - by Paul Philco322 - 05-20-2018, 06:18 PM
RE: Sears Model 3351 132.802 - by David - 05-20-2018, 06:37 PM
RE: Sears Model 3351 132.802 - by 35Z5 - 05-20-2018, 07:08 PM
RE: Sears Model 3351 132.802 - by David - 05-20-2018, 08:37 PM
RE: Sears Model 3351 132.802 - by Paul Philco322 - 05-20-2018, 09:16 PM
RE: Sears Model 3351 132.802 - by Arran - 05-21-2018, 04:35 AM
RE: Sears Model 3351 132.802 - by 35Z5 - 05-21-2018, 08:38 AM
RE: Sears Model 3351 132.802 - by David - 05-24-2018, 05:55 PM
RE: Sears Model 3351 132.802 - by Arran - 05-25-2018, 05:52 AM
RE: Sears Model 3351 132.802 - by 35Z5 - 05-25-2018, 10:23 AM
RE: Sears Model 3351 132.802 - by David - 05-27-2018, 01:04 PM
RE: Sears Model 3351 132.802 - by David - 05-30-2018, 04:34 PM
RE: Sears Model 3351 132.802 - by David - 06-12-2018, 07:48 PM
RE: Sears Model 3351 132.802 - by David - 07-14-2018, 08:15 PM
RE: Sears Model 3351 132.802 - by David - 10-28-2018, 08:47 PM
RE: Sears Model 3351 132.802 - by 35Z5 - 10-29-2018, 10:31 AM
RE: Sears Model 3351 132.802 - by David - 10-29-2018, 05:08 PM
There are currently 9966 online users. [Complete List]
» 1 Member(s) | 9965 Guest(s)
