Sears Model 3351 132.802
Generally sets with this tube line up were designed prior to registration of 12SA7, 12SK7, 12SQ7, 50L6 & 35Z5... Within two or three months most mfgrs switched to the later types...
Tom
Sears Model 3351 132.802 - by David - 05-20-2018, 06:05 PM
RE: Sears Model 3351 132.802 - by David - 05-20-2018, 06:07 PM
RE: Sears Model 3351 132.802 - by Paul Philco322 - 05-20-2018, 06:18 PM
RE: Sears Model 3351 132.802 - by David - 05-20-2018, 06:37 PM
RE: Sears Model 3351 132.802 - by 35Z5 - 05-20-2018, 07:08 PM
RE: Sears Model 3351 132.802 - by David - 05-20-2018, 08:37 PM
RE: Sears Model 3351 132.802 - by Paul Philco322 - 05-20-2018, 09:16 PM
RE: Sears Model 3351 132.802 - by Arran - 05-21-2018, 04:35 AM
RE: Sears Model 3351 132.802 - by 35Z5 - 05-21-2018, 08:38 AM
RE: Sears Model 3351 132.802 - by David - 05-24-2018, 05:55 PM
RE: Sears Model 3351 132.802 - by Arran - 05-25-2018, 05:52 AM
RE: Sears Model 3351 132.802 - by 35Z5 - 05-25-2018, 10:23 AM
RE: Sears Model 3351 132.802 - by David - 05-27-2018, 01:04 PM
RE: Sears Model 3351 132.802 - by David - 05-30-2018, 04:34 PM
RE: Sears Model 3351 132.802 - by David - 06-12-2018, 07:48 PM
RE: Sears Model 3351 132.802 - by David - 07-14-2018, 08:15 PM
RE: Sears Model 3351 132.802 - by David - 10-28-2018, 08:47 PM
RE: Sears Model 3351 132.802 - by 35Z5 - 10-29-2018, 10:31 AM
RE: Sears Model 3351 132.802 - by David - 10-29-2018, 05:08 PM
There are currently 9702 online users. [Complete List]
» 3 Member(s) | 9699 Guest(s)
