Sears Model 3351 132.802
I noticed the 35Z4 & 35L6... 35Z5 & 50L6 were both introduced after those two types... As stated a deal probablyinfluenced tube choice...
I didn't catch the 12SQ7, should have been more observant...
Colonial was source 101, 132 would indicate it was built by Noblitt-Sparks(Arvin)... . Sears used Arvin for some audio products till they stopped building sets in the late '80s/early '90s...
Tom
Sears Model 3351 132.802 - by David - 05-20-2018, 06:05 PM
RE: Sears Model 3351 132.802 - by David - 05-20-2018, 06:07 PM
RE: Sears Model 3351 132.802 - by Paul Philco322 - 05-20-2018, 06:18 PM
RE: Sears Model 3351 132.802 - by David - 05-20-2018, 06:37 PM
RE: Sears Model 3351 132.802 - by 35Z5 - 05-20-2018, 07:08 PM
RE: Sears Model 3351 132.802 - by David - 05-20-2018, 08:37 PM
RE: Sears Model 3351 132.802 - by Paul Philco322 - 05-20-2018, 09:16 PM
RE: Sears Model 3351 132.802 - by Arran - 05-21-2018, 04:35 AM
RE: Sears Model 3351 132.802 - by 35Z5 - 05-21-2018, 08:38 AM
RE: Sears Model 3351 132.802 - by David - 05-24-2018, 05:55 PM
RE: Sears Model 3351 132.802 - by Arran - 05-25-2018, 05:52 AM
RE: Sears Model 3351 132.802 - by 35Z5 - 05-25-2018, 10:23 AM
RE: Sears Model 3351 132.802 - by David - 05-27-2018, 01:04 PM
RE: Sears Model 3351 132.802 - by David - 05-30-2018, 04:34 PM
RE: Sears Model 3351 132.802 - by David - 06-12-2018, 07:48 PM
RE: Sears Model 3351 132.802 - by David - 07-14-2018, 08:15 PM
RE: Sears Model 3351 132.802 - by David - 10-28-2018, 08:47 PM
RE: Sears Model 3351 132.802 - by 35Z5 - 10-29-2018, 10:31 AM
RE: Sears Model 3351 132.802 - by David - 10-29-2018, 05:08 PM
There are currently 10360 online users. [Complete List]
» 1 Member(s) | 10359 Guest(s)
