41-604 electrolytic
So, I now just get a hum. This is the case regardless of turning on the radio or the phono. I do see the tubes lighting up.
From what I've read, I'm still looking at the e caps and their wiring being the culprit, correct?
I'm quite sure I've got them wired in the correct direction (they're axial, with a nipple preceding the lead on the negative side).
41-604 electrolytic - by NickinMD - 05-19-2018, 06:42 PM
RE: 41-604 electrolytic - by Kenneth F. Besso Jr. - 05-19-2018, 07:28 PM
RE: 41-604 electrolytic - by NickinMD - 05-19-2018, 07:49 PM
RE: 41-604 electrolytic - by Radioroslyn - 05-19-2018, 08:00 PM
RE: 41-604 electrolytic - by 35Z5 - 05-19-2018, 08:05 PM
RE: 41-604 electrolytic - by NickinMD - 05-21-2018, 06:02 PM
RE: 41-604 electrolytic - by NickinMD - 05-21-2018, 10:16 PM
RE: 41-604 electrolytic - by Radioroslyn - 05-21-2018, 10:32 PM
91H Code 126 Restore
