Sherwood S-7900A
If your amp works fine, this means the cap is ok. If it dried up you'd likely notice. It's a good cap, why bother?
Sherwood S-7900A - by Ron Ramirez - 06-25-2016, 08:17 PM
RE: Sherwood S-7900A - by Ron Ramirez - 06-25-2016, 08:21 PM
RE: Sherwood S-7900A - by Ron Ramirez - 06-25-2016, 08:23 PM
RE: Sherwood S-7900A - by Ron Ramirez - 06-25-2016, 08:26 PM
RE: Sherwood S-7900A - by Ron Ramirez - 06-25-2016, 08:29 PM
RE: Sherwood S-7900A - by Arran - 06-26-2016, 04:00 AM
RE: Sherwood S-7900A - by Ron Ramirez - 06-25-2016, 08:35 PM
RE: Sherwood S-7900A - by morzh - 06-26-2016, 11:46 AM
RE: Sherwood S-7900A - by Ron Ramirez - 06-26-2016, 05:29 PM
RE: Sherwood S-7900A - by KCMike - 06-26-2016, 06:20 PM
RE: Sherwood S-7900A - by Eliot Ness - 06-26-2016, 06:52 PM
RE: Sherwood S-7900A - by Ron Ramirez - 06-26-2016, 07:38 PM
RE: Sherwood S-7900A - by Ed Locker - 06-27-2016, 09:35 AM
RE: Sherwood S-7900A - by Ron Ramirez - 06-27-2016, 04:27 PM
RE: Sherwood S-7900A - by Arran - 06-28-2016, 04:15 AM
RE: Sherwood S-7900A - by Ron Ramirez - 06-28-2016, 07:55 PM
RE: Sherwood S-7900A - by Arran - 06-29-2016, 04:15 AM
RE: Sherwood S-7900A - by Ron Ramirez - 12-22-2016, 10:58 PM
RE: Sherwood S-7900A - by morzh - 12-22-2016, 11:31 PM
RE: Sherwood S-7900A - by Ron Ramirez - 12-23-2016, 12:09 AM
RE: Sherwood S-7900A - by morzh - 12-23-2016, 12:15 AM
RE: Sherwood S-7900A - by Ron Ramirez - 12-23-2016, 09:38 AM
RE: Sherwood S-7900A - by morzh - 12-23-2016, 10:12 AM
RE: Sherwood S-7900A - by Ron Ramirez - 12-23-2016, 04:25 PM
RE: Sherwood S-7900A - by rocketeer - 12-23-2016, 08:55 PM
RE: Sherwood S-7900A - by KCMike - 12-23-2016, 09:48 PM
RE: Sherwood S-7900A - by Ron Ramirez - 05-22-2018, 10:18 PM
RE: Sherwood S-7900A - by morzh - 05-22-2018, 11:06 PM
RE: Sherwood S-7900A - by Ron Ramirez - 05-23-2018, 06:06 AM
RE: Sherwood S-7900A - by morzh - 05-23-2018, 07:39 AM
RE: Sherwood S-7900A - by Ron Ramirez - 05-23-2018, 09:08 AM
