Interesting new find
I love the look of Australian Walnut on that Parmak that Russ owns, that's an unusual choice of wood for an American set for some reason, though they used a lot of it in Canadian sets, and Australian ones too obviously.
Interesting new find - by murf - 05-20-2018, 06:48 PM
RE: Interesting new find - by OldRestorer - 05-21-2018, 12:25 PM
RE: Interesting new find - by murf - 05-21-2018, 05:28 PM
RE: Interesting new find - by Phlogiston - 05-21-2018, 07:12 PM
RE: Interesting new find - by OldRestorer - 05-22-2018, 11:38 AM
RE: Interesting new find - by Arran - 05-24-2018, 02:38 AM
RE: Interesting new find - by murf - 05-24-2018, 03:27 PM
RE: Interesting new find - by Phlogiston - 05-24-2018, 04:43 PM
RE: Interesting new find - by murf - 05-24-2018, 07:41 PM
RE: Interesting new find - by Arran - 05-25-2018, 05:07 AM
There are currently 10191 online users. [Complete List]
» 3 Member(s) | 10188 Guest(s)
