Sears Model 3351 132.802
The prefix codes Sears used were of their own assignment, no relation to RMA/EIA etc.
Apparently code 132 continued to be Arvin through it's lifetime with Sears, EIA code was 248(at least in 1959). Some of the Sears codes changed as mfgrs were dropped then later returned.
Tom
Sears Model 3351 132.802 - by David - 05-20-2018, 06:05 PM
RE: Sears Model 3351 132.802 - by David - 05-20-2018, 06:07 PM
RE: Sears Model 3351 132.802 - by Paul Philco322 - 05-20-2018, 06:18 PM
RE: Sears Model 3351 132.802 - by David - 05-20-2018, 06:37 PM
RE: Sears Model 3351 132.802 - by 35Z5 - 05-20-2018, 07:08 PM
RE: Sears Model 3351 132.802 - by David - 05-20-2018, 08:37 PM
RE: Sears Model 3351 132.802 - by Paul Philco322 - 05-20-2018, 09:16 PM
RE: Sears Model 3351 132.802 - by Arran - 05-21-2018, 04:35 AM
RE: Sears Model 3351 132.802 - by 35Z5 - 05-21-2018, 08:38 AM
RE: Sears Model 3351 132.802 - by David - 05-24-2018, 05:55 PM
RE: Sears Model 3351 132.802 - by Arran - 05-25-2018, 05:52 AM
RE: Sears Model 3351 132.802 - by 35Z5 - 05-25-2018, 10:23 AM
RE: Sears Model 3351 132.802 - by David - 05-27-2018, 01:04 PM
RE: Sears Model 3351 132.802 - by David - 05-30-2018, 04:34 PM
RE: Sears Model 3351 132.802 - by David - 06-12-2018, 07:48 PM
RE: Sears Model 3351 132.802 - by David - 07-14-2018, 08:15 PM
RE: Sears Model 3351 132.802 - by David - 10-28-2018, 08:47 PM
RE: Sears Model 3351 132.802 - by 35Z5 - 10-29-2018, 10:31 AM
RE: Sears Model 3351 132.802 - by David - 10-29-2018, 05:08 PM
There are currently 8695 online users. [Complete List]
» 3 Member(s) | 8692 Guest(s)
