41-81 AVC Problem?
Thanks, guys, for the tips. I'll probably have time this week to look at the things you suggested.
I replaced the detector (1H5G) with an NOS tube, and it made no difference. I don't have any other way to test the tube, but I am reasonably sure that the original detector is fine, or at least as good as the NOS tube.
More later, and thanks again for the help.
John Honeycutt
41-81 AVC Problem? - by Raleigh - 06-07-2010, 12:09 AM
Re: 41-81 AVC Problem? - by codefox1 - 06-07-2010, 10:28 AM
Re: 41-81 AVC Problem? - by 7estatdef - 06-07-2010, 09:19 PM
Re: 41-81 AVC Problem? - by Raleigh - 06-18-2010, 02:02 PM
Re: 41-81 AVC Problem? - by rghines1 - 06-19-2010, 02:14 PM
Re: 41-81 AVC Problem? - by Chuck Schwark - 06-19-2010, 06:23 PM
Re: 41-81 AVC Problem? - by Raleigh - 06-21-2010, 09:52 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
