Philco 37-690 Restoration
Thanks Paul & Mike(Morzh) I have restored other Philcos in the past but this was the most challenging. I took my time and took lots of pictures and printed out the service bulletin which was a big help. I did find a little bit ago the proper 3/8" high rubber receiver chassis support grommets so that should take care of the height issue. All I need to do is to fabricate a bottom cover for the receiver chassis. Soon I'll be starting on my 37-116 cabinet which needs to be stripped and refinished (not looking forward to that).   Ken
Philco 37-690 Restoration - by Kenradio - 05-11-2018, 05:33 AM
RE: Philco 37-690 Restoration - by Ron Ramirez - 05-11-2018, 07:47 PM
RE: Philco 37-690 Restoration - by Kenradio - 05-12-2018, 05:48 AM
RE: Philco 37-690 Restoration - by morzh - 05-12-2018, 10:10 PM
RE: Philco 37-690 Restoration - by Kenradio - 05-13-2018, 04:51 AM
RE: Philco 37-690 Restoration - by Ron Ramirez - 05-13-2018, 07:38 AM
RE: Philco 37-690 Restoration - by Kenradio - 05-13-2018, 09:03 AM
RE: Philco 37-690 Restoration - by GarySP - 05-13-2018, 09:44 AM
RE: Philco 37-690 Restoration - by Phlogiston - 05-13-2018, 10:21 AM
RE: Philco 37-690 Restoration - by Kenradio - 05-13-2018, 04:30 PM
RE: Philco 37-690 Restoration - by Ron Ramirez - 05-13-2018, 07:42 PM
RE: Philco 37-690 Restoration - by Ron Ramirez - 05-13-2018, 07:44 PM
RE: Philco 37-690 Restoration - by Kenradio - 05-15-2018, 06:26 AM
RE: Philco 37-690 Restoration - by Kenradio - 05-15-2018, 06:36 AM
RE: Philco 37-690 Restoration - by morzh - 05-15-2018, 08:14 AM
RE: Philco 37-690 Restoration - by Ron Ramirez - 05-15-2018, 09:05 AM
RE: Philco 37-690 Restoration - by Kenradio - 05-15-2018, 11:22 AM
RE: Philco 37-690 Restoration - by tbone - 05-19-2018, 08:19 AM
RE: Philco 37-690 Restoration - by Phlogiston - 05-19-2018, 09:39 AM
RE: Philco 37-690 Restoration - by Ron Ramirez - 05-19-2018, 02:54 PM
RE: Philco 37-690 Restoration - by Kenradio - 05-19-2018, 06:02 PM
RE: Philco 37-690 Restoration - by tbone - 05-20-2018, 08:15 PM
RE: Philco 37-690 Restoration - by Kenradio - 05-21-2018, 04:37 AM
RE: Philco 37-690 Restoration - by Kenradio - 05-26-2018, 06:19 AM
RE: Philco 37-690 Restoration - by WyTex - 05-26-2018, 08:01 AM
RE: Philco 37-690 Restoration - by morzh - 05-26-2018, 10:40 AM
RE: Philco 37-690 Restoration - by Kenradio - 05-26-2018, 12:29 PM
RE: Philco 37-690 Restoration - by KCMike - 05-26-2018, 12:32 PM
RE: Philco 37-690 Restoration - by morzh - 05-26-2018, 01:44 PM
RE: Philco 37-690 Restoration - by Kenradio - 05-26-2018, 02:40 PM
RE: Philco 37-690 Restoration - by morzh - 05-26-2018, 02:58 PM
RE: Philco 37-690 Restoration - by Kenradio - 05-26-2018, 03:16 PM
RE: Philco 37-690 Restoration - by tbone - 06-09-2018, 06:38 AM
RE: Philco 37-690 Restoration - by Kenradio - 06-09-2018, 06:50 PM
91H Code 126 Restore
There are currently 2162 online users. [Complete List]
» 2 Member(s) | 2160 Guest(s)
