A Philco 38-690 Restoration
May 27.
If anyone is still reading...
Only the oscillator unit remains, along with the sub-base.
[Image: http://www.philcoradio.com/images/phorum...90_075.jpg]
[Image: http://www.philcoradio.com/images/phorum...90_076.jpg]
[Image: http://www.philcoradio.com/images/phorum...90_077.jpg]
You can tell from these photos why I am replacing the wiring.
I removed the oscillator section from the sub-base and began replacing all of the wires.
By the time I quit tonight, this is how it looked:
[Image: http://www.philcoradio.com/images/phorum...90_078.jpg]
Almost finished. I need to replace the RF tube socket, a couple more wires, and a component or two. Then I will examine the actual oscillator unit, make sure the coils are good, then replace some wires in the actual oscillator unit before I start putting it all back together again.
A Philco 38-690 Restoration - by Ron Ramirez - 05-25-2018, 10:50 PM
RE: A Philco 38-690 Restoration - by Ron Ramirez - 05-25-2018, 10:53 PM
RE: A Philco 38-690 Restoration - by Ron Ramirez - 05-25-2018, 11:04 PM
RE: A Philco 38-690 Restoration - by Ron Ramirez - 05-25-2018, 11:11 PM
RE: A Philco 38-690 Restoration - by Ron Ramirez - 05-25-2018, 11:14 PM
RE: A Philco 38-690 Restoration - by Ron Ramirez - 05-25-2018, 11:19 PM
RE: A Philco 38-690 Restoration - by Arran - 05-26-2018, 02:26 AM
RE: A Philco 38-690 Restoration - by Ron Ramirez - 05-26-2018, 08:20 AM
RE: A Philco 38-690 Restoration - by Ron Ramirez - 05-26-2018, 08:25 AM
RE: A Philco 38-690 Restoration - by Ron Ramirez - 05-26-2018, 08:31 AM
RE: A Philco 38-690 Restoration - by Ron Ramirez - 05-26-2018, 09:03 AM
RE: A Philco 38-690 Restoration - by Ron Ramirez - 05-26-2018, 09:31 AM
RE: A Philco 38-690 Restoration - by Ron Ramirez - 05-26-2018, 09:49 AM
RE: A Philco 38-690 Restoration - by Ron Ramirez - 05-26-2018, 10:02 AM
RE: A Philco 38-690 Restoration - by Ron Ramirez - 05-26-2018, 10:12 AM
RE: A Philco 38-690 Restoration - by morzh - 05-26-2018, 10:35 AM
RE: A Philco 38-690 Restoration - by Ron Ramirez - 05-26-2018, 05:54 PM
RE: A Philco 38-690 Restoration - by Ron Ramirez - 05-26-2018, 05:58 PM
RE: A Philco 38-690 Restoration - by Ron Ramirez - 05-26-2018, 06:01 PM
RE: A Philco 38-690 Restoration - by Ron Ramirez - 05-26-2018, 06:08 PM
RE: A Philco 38-690 Restoration - by Ron Ramirez - 05-26-2018, 06:20 PM
RE: A Philco 38-690 Restoration - by Ron Ramirez - 05-26-2018, 06:58 PM
RE: A Philco 38-690 Restoration - by Ron Ramirez - 05-26-2018, 09:37 PM
RE: A Philco 38-690 Restoration - by Ron Ramirez - 05-27-2018, 10:17 PM
RE: A Philco 38-690 Restoration - by Arran - 05-28-2018, 05:04 AM
RE: A Philco 38-690 Restoration - by WyTex - 05-28-2018, 07:03 AM
RE: A Philco 38-690 Restoration - by Ron Ramirez - 05-28-2018, 08:03 AM
RE: A Philco 38-690 Restoration - by Ron Ramirez - 05-28-2018, 08:15 AM
RE: A Philco 38-690 Restoration - by Ron Ramirez - 05-28-2018, 05:59 PM
RE: A Philco 38-690 Restoration - by KCMike - 05-28-2018, 07:36 PM
RE: A Philco 38-690 Restoration - by Ron Ramirez - 05-28-2018, 09:21 PM
RE: A Philco 38-690 Restoration - by Arran - 05-29-2018, 03:32 AM
RE: A Philco 38-690 Restoration - by Brad Winder - 05-30-2018, 10:28 AM
RE: A Philco 38-690 Restoration - by Ron Ramirez - 05-30-2018, 09:08 PM
RE: A Philco 38-690 Restoration - by tbone - 05-31-2018, 07:46 AM
RE: A Philco 38-690 Restoration - by Ron Ramirez - 05-31-2018, 10:43 AM
RE: A Philco 38-690 Restoration - by Ron Ramirez - 05-31-2018, 10:37 PM
RE: A Philco 38-690 Restoration - by Ron Ramirez - 06-01-2018, 11:11 PM
RE: A Philco 38-690 Restoration - by Arran - 06-02-2018, 02:35 AM
RE: A Philco 38-690 Restoration - by Ron Ramirez - 06-02-2018, 07:47 AM
RE: A Philco 38-690 Restoration - by Ron Ramirez - 06-02-2018, 09:54 AM
RE: A Philco 38-690 Restoration - by Ron Ramirez - 06-02-2018, 10:16 AM
RE: A Philco 38-690 Restoration - by mikethedruid - 06-02-2018, 12:46 PM
RE: A Philco 38-690 Restoration - by WyTex - 06-02-2018, 01:24 PM
RE: A Philco 38-690 Restoration - by Ed Locker - 06-02-2018, 07:25 PM
RE: A Philco 38-690 Restoration - by Kenradio - 06-02-2018, 07:46 PM
RE: A Philco 38-690 Restoration - by Ron Ramirez - 06-02-2018, 11:21 PM
RE: A Philco 38-690 Restoration - by EdHolland - 06-03-2018, 10:39 AM
RE: A Philco 38-690 Restoration - by morzh - 06-03-2018, 11:20 AM
RE: A Philco 38-690 Restoration - by Ron Ramirez - 06-03-2018, 11:57 AM
RE: A Philco 38-690 Restoration - by sam - 06-03-2018, 02:07 PM
RE: A Philco 38-690 Restoration - by Ron Ramirez - 06-03-2018, 02:22 PM
RE: A Philco 38-690 Restoration - by tbone - 06-03-2018, 09:04 PM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 4410 online users. [Complete List]
» 2 Member(s) | 4408 Guest(s)
