detector coil replacement on 32 Volt Delco Farm Radio
Thanks again, Terry. I know that gator wiring anything in isn't ideal or the way to go. We removed the coil just to see if we could find the break. I have one of the AES RF coils you recommended on order so hopefully that will do the trick. Will keep you posted.
There are currently 8410 online users. [Complete List]
» 1 Member(s) | 8409 Guest(s)
