Stewart Warner R-137-A
Ok guy's,
Got it to load the pics of the questionable caps tonight.
You can see the extra long 15 volt cap in one picture and the other picture shows the cap with the flexible resistor attached.
Wondering what the purpose of the flexible resistor is that is mounted to the cap?
I have replaced those caps before by just reattaching the resistor to the new cap.
But always wondered why it was done this way.
The other pic that shows the extra long cap with the weird values.
What would be a suitable replacement. Don't have anything even close to those values.
Thanks, murf
[Image: http://i1161.photobucket.com/albums/q509...C_0363.jpg][Image: http://i1161.photobucket.com/albums/q509...C_0362.jpg]
Stewart Warner R-137-A - by murf - 05-01-2018, 06:21 PM
RE: Stewart Warner R-137-A - by David - 05-01-2018, 07:30 PM
RE: Stewart Warner R-137-A - by murf - 05-01-2018, 09:58 PM
RE: Stewart Warner R-137-A - by Eliot Ness - 05-02-2018, 07:22 AM
RE: Stewart Warner R-137-A - by murf - 05-02-2018, 10:19 PM
RE: Stewart Warner R-137-A - by gregb - 05-02-2018, 10:46 PM
RE: Stewart Warner R-137-A - by Arran - 05-03-2018, 12:21 AM
RE: Stewart Warner R-137-A - by murf - 05-03-2018, 03:16 PM
RE: Stewart Warner R-137-A - by murf - 05-03-2018, 09:15 PM
RE: Stewart Warner R-137-A - by gregb - 05-03-2018, 09:41 PM
RE: Stewart Warner R-137-A - by murf - 05-04-2018, 06:40 PM
RE: Stewart Warner R-137-A - by gregb - 05-04-2018, 07:17 PM
RE: Stewart Warner R-137-A - by murf - 05-11-2018, 09:55 PM
RE: Stewart Warner R-137-A - by murf - 05-29-2018, 09:27 PM
RE: Stewart Warner R-137-A - by Radioroslyn - 05-29-2018, 10:16 PM
RE: Stewart Warner R-137-A - by murf - 05-30-2018, 04:46 PM
RE: Stewart Warner R-137-A - by Radioroslyn - 05-30-2018, 04:54 PM
RE: Stewart Warner R-137-A - by murf - 05-31-2018, 09:27 PM
There are currently 9890 online users. [Complete List]
» 2 Member(s) | 9888 Guest(s)
