  • 1 Vote(s) - 4 Average
RF Coil for Model 20 or 20A
Hi all;
I am restoring a Model 20A and need to replace an inter-stage transformer RF coil shown in the schematic as number 7.
This is one of the type mounted on a hollow tube like a toilet paper roll and inserted head into a metal can.
Any pointers to where I can find a replacement would be greatly appreciated. See attached schematic for reference.
Thanks.
Howard
RF Coil for Model 20 or 20A - by hrensin - 05-29-2018, 10:07 PM
RE: RF Coil for Model 20 or 20A - by morzh - 05-30-2018, 08:59 AM
RE: RF Coil for Model 20 or 20A - by KCMike - 05-30-2018, 11:23 AM
RE: RF Coil for Model 20 or 20A - by hrensin - 05-30-2018, 02:54 PM
RE: RF Coil for Model 20 or 20A - by morzh - 05-30-2018, 04:43 PM
RE: RF Coil for Model 20 or 20A - by hrensin - 05-30-2018, 04:59 PM
The speaker table error?
Philco 70 antenna lead
