  • 1 Vote(s) - 4 Average
RF Coil for Model 20 or 20A
A-ha! Well, as Terry said, those are not too difficult to rewind.
RF Coil for Model 20 or 20A - by hrensin - 05-29-2018, 10:07 PM
RE: RF Coil for Model 20 or 20A - by morzh - 05-30-2018, 08:59 AM
RE: RF Coil for Model 20 or 20A - by KCMike - 05-30-2018, 11:23 AM
RE: RF Coil for Model 20 or 20A - by hrensin - 05-30-2018, 02:54 PM
RE: RF Coil for Model 20 or 20A - by morzh - 05-30-2018, 04:43 PM
RE: RF Coil for Model 20 or 20A - by hrensin - 05-30-2018, 04:59 PM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 4055 online users. [Complete List]
» 1 Member(s) | 4054 Guest(s)
