Philco 37-11 Automatic dial muting problem
When you push in the arm in it thru the switch contact grounds the audio signal coming out of the volume control wiper. Check the resistance  from the switch to ground, should be 0 when switch is closed. Also check the resistance from the ground end of the volume control  to ground, again should be 0.
RE: Philco 37-11 Automatic dial muting problem - by Radioroslyn - 05-30-2018, 01:59 PM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 3910 online users. [Complete List]
» 1 Member(s) | 3909 Guest(s)
