AM transmitter
In an effort to respect the authenticity of my radio, I ordered an AM transmitter kit off the Bay.  I don't yet have an antenna, and but wanted to show off the case I made for it.  Basically, I aged a couple sheets of printer paper in coffee then used them to print out the 1941 Philco ad posted on the Phorum. I then decoupaged them onto the cardboard box that came with the transmitter kit.
https://photos.app.goo.gl/32Mw5RptKXhU8kHN2
https://photos.app.goo.gl/zpwDLaOvryw2Xmll1
AM transmitter - by NickinMD - 05-30-2018, 03:26 PM
RE: AM transmitter - by leftwing25 - 05-31-2018, 04:23 PM
RE: AM transmitter - by David - 05-31-2018, 09:35 PM
There are currently 9120 online users. [Complete List]
» 2 Member(s) | 9118 Guest(s)
