Which Mohawk toner - Tone Finish or Ultra Classic?
Hey Phlogiston-
I'm trying to soak in as many finishing tips as I can from this forum, but I'm a little confused by your "never spray directly at the surface" tip. Did you mean to say: spray at a low angle to the surface as opposed to 90 degrees (perpendicular) to the surface? Or am I incorrectly interpreting your comment.
RE: Which Mohawk toner - Tone Finish or Ultra Classic? - by mark123 - 05-31-2018, 01:52 PM
RE: Zenith 12s370 Refinish - by Ron Ramirez - 05-28-2018, 09:07 PM
RE: Zenith 12s370 Refinish - by OZ4 - 05-29-2018, 03:48 PM
RE: Zenith 12s370 Refinish - by Ron Ramirez - 05-29-2018, 05:38 PM
RE: Zenith 12s370 Refinish - by OZ4 - 05-29-2018, 06:33 PM
Eico 232 VTVM Schematic
There are currently 9382 online users. [Complete List]
» 2 Member(s) | 9380 Guest(s)
