Now to dive in!
Welcome!
Not a bad radio. Be careful, it is Ac/DC set without transformer, so some extra being careful while working on the powered unit is needed, preferably with isolation transformer.
Now to dive in! - by Desmoduece - 06-01-2018, 02:42 PM
RE: Now to dive in! - by morzh - 06-01-2018, 04:50 PM
RE: Now to dive in! - by Desmoduece - 06-01-2018, 05:58 PM
RE: Now to dive in! - by klondike98 - 06-01-2018, 07:40 PM
RE: Now to dive in! - by Nathan Slingerland - 06-02-2018, 01:17 AM
RE: Now to dive in! - by NickinMD - 06-02-2018, 06:47 AM
RE: Now to dive in! - by Desmoduece - 06-02-2018, 09:02 AM
RE: Now to dive in! - by Paul Philco322 - 06-03-2018, 09:12 AM
There are currently 10195 online users. [Complete List]
» 3 Member(s) | 10192 Guest(s)
