37/38 Station Call Letter Tab Trivia
The station call letter tabs on the 38-3 I recently finished working on have the double lettering (see photo).  The ones I can make out are/were stations in the northeast, best I can tell.
WEAF - New York City
WLW - Cincinnati
WOR - New Jersey
WJZ - New York
WABC - New York City
KDKA? - Pittsburgh
Would dealers in a multi-state area all use the same station call letter kit?  This particular radio has probably spent all its life in PA.
Larry
37/38 Station Call Letter Tab Trivia - by Greg - 06-01-2018, 08:26 PM
RE: 37/38 Station Call Letter Tab Trivia - by LarryFS - 06-02-2018, 11:30 AM
There are currently 10240 online users. [Complete List]
» 1 Member(s) | 10239 Guest(s)
