37-650, What do you think?
Quick, slightly blurry photo of a 37-650X...
[Image: http://i326.photobucket.com/albums/k420/...7-650X.jpg]
Another refinishing job by Barry Jones of Evansville. You can see where the shading should be in certain areas.
If your cabinet was finished with a true lacquer finish, it can still be made to look like this. All it would need is some light sanding, then some extra dark walnut toning lacquer sprayed on the trim as shown above. Follow that up with some coats of clear lacquer. I believe it should have extra dark walnut on the trim instead of the medium dark walnut used on the cabinet above, but this cabinet still looks better than a single-color (monotone) finish.
37-650, What do you think? - by Guest - 06-13-2010, 05:45 PM
RE: 37-650, What do you think? - by Phlogiston - 03-10-2013, 01:29 AM
RE: 37-650, What do you think? - by ipwizard - 03-14-2013, 03:30 PM
RE: 37-650, What do you think? - by Tom Hamilton - 03-24-2013, 01:33 PM
Re: 37-650, What do you think? - by Ron Ramirez - 06-13-2010, 08:04 PM
Re: 37-650, What do you think? - by Guest - 06-13-2010, 10:33 PM
Re: 37-650, What do you think? - by hotrod - 06-17-2010, 02:16 AM
Re: 37-650, What do you think? - by Guest - 06-20-2010, 10:26 AM
Re: 37-650, What do you think? - by Ron Ramirez - 06-23-2010, 03:03 PM
Re: 37-650, What do you think? - by Arran - 08-28-2010, 09:53 PM
Philco 630csx power cord
New member
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
There are currently 2576 online users. [Complete List]
» 2 Member(s) | 2574 Guest(s)
