37-630 rubber mounting washers ?
Ed also has chassis bolts available, but having sold my 37-630 I can't recall which length it uses. Here's a link to the page with them:
http://renovatedradios.com/productlist.php?category=107
RE: 37-630 rubber mounting washers ? - by NostalgiaRadioTime - 06-03-2018, 12:07 PM
Eico 232 VTVM Schematic
There are currently 8871 online users. [Complete List]
» 2 Member(s) | 8869 Guest(s)
