37-630 rubber mounting washers ?
I just bought 4 of each length, at $0.50 each that only comes to $4, also bought the rubber mounts for the RF section on the chassis. So I should be all set as far as the hardware stuff goes. Thanks, Greg.
Mike
RE: 37-630 rubber mounting washers ? - by mikethedruid - 06-03-2018, 01:21 PM
