Help with 38-9 Plastic Dial
Good to hear of your success ! Keep us abreast of your work, and don't hesitate to ask questions. There are folks here who are VERY knowledgeable about these radios, and some who have probably tackled the same model. They will be able to give you tips and help when you run into problems.
Help with 38-9 Plastic Dial - by philconerd - 06-02-2018, 03:43 PM
RE: Help with 38-9 Plastic Dial - by philconerd - 06-02-2018, 04:00 PM
RE: Help with 38-9 Plastic Dial - by LarryFS - 06-02-2018, 05:02 PM
RE: Help with 38-9 Plastic Dial - by philconerd - 06-02-2018, 08:07 PM
RE: Help with 38-9 Plastic Dial - by mikethedruid - 06-03-2018, 03:30 PM
The speaker table error?
Philco 70 antenna lead
